1 - 4 of 4 Posts
My fuel pump will prime for the determined time set by the BS3 box. I can fire the car and it will run and hold pressure. After about 5-10 minutes the pump just turns off. My power is coming off a junction box, and the ground right off the battery. All of my connectors are tight and continuity tested good on them. Im using a power relay module, it doesnt feel like it is hot or anything like that. Just wondering what you guys think I should check next
x2 verify whether or not the pump is receiving power, if not trace the circuit back to the BS3 (junction box, relay, signal wire, etc.). Hopefully you can find the issue.
Im just retarded, the J-fuse I was using on the module was really lose, fixed that and no issues now.
1 - 4 of 4 Posts
