1 - 20 of 57 Posts
How big is your motor?
How much nitrous?
How fast have you gone?
How much does the car weigh?
What suspension are you on?
Smoke Em if you got Em
I think Marlow is the fastest so far.
588 1 hit, 3400lbs Gen 3 camaro, been 4.93 and 7.60s I think.
this is the direction im heading in 577 BBF on 1 gun..im thinking it will take 350-400 to go 90's @ 3250
I'm working on a new 572 motor and put ladder bars under the Nova to see if I can get it down in the low 5.'s on 1 kit. My head porter seem to think we can get it done. We'll see soon
Keep the info coming. I'd like to hear more.
ls1 s/s notch on 28s
pirez in his words dusted the nova off from sitting for 2yrs..pulled the bitch out and went racing and went 5 teens i think it was..pretty sure motor is a 540ci deal..not bad for a old chassis an leafs
J&E POWER!!
no more ODR?? or are you building another car for x275??
X275 Derby Winner!
585, RFD headed, 1 gun... Should see some 4.9x soon!
DonB
What heads are you using? I'm building a 598 just trying to decide on heads. I'm leaning towards the Foxlake A460s I think C heads will keep me out of a lot of classes.
93 mustang coupe 565 bbc conv head 1 gun 300 shot stock susp 3260lbs been a 5.20 at 136 on a mickey 275. i think i could have went in the teens on a hoosier
Motorsport A460's on mine, not the best but they have been worked on pretty heavily...the best "shelf" A460 is from Total Engine Airflow...but at 598 you may want to go C headed anyhow since the x275 c.i. limit is 588.
Man, not trying to tell you what to do, but if it were me I'd leave the stock suspension on there. Personally with a radial, I think it works better than a ladder bar. Like I said though....just my .02.
Discussion Starter #16
I plan on running the 275's and putting 10.5's on it at a later date.
Discussion Starter #17
I don't think so. Not on all combo's.
Why is everyone running only one stage? Can you not run 3 or 4 hits because that is the way go. I bet a serious 582 big block with 3 kits will go high 4.70s
WWWWWWWWWWWWWWWWWWWWWWWWW
maybe because x275 is limited to one stage on big block cars....... and that is what most of the 275 cars run..
1 - 20 of 57 Posts
