1 - 6 of 6 Posts
Can anybody send me some pics of there big block chevy so i can get some ideas on how i want to mount the altinator and the moroso vac pump set,,thanks....:smt077
Its mounted with madman motor plate.
I am in the same boat as you. We have a front motor plate and the steering box takes up the lower left and I really didn't want to cut the plate on the right. If you want to run a standard water pump or one of the high doller electric ones that has an idler pulley on it you can mount stuff high and the bracket on the link about would work nicely.
Motorboatin SOB
Forgot to mention we have a front and mid motor plate as well. Had to drill a hold for the excitier wire to go through, but the mount is great. uses the top head bolt on the front of the head and the 2 left side water pump bolts.
1 - 6 of 6 Posts
