61 - 66 of 66 Posts
At Pomona, spinning during the Hot Rod In n Out 70th the car ran [email protected]
At Irwindale 1/8th mile it ran [email protected] several times
3800 lb on a 10.5 tire. Never got the car sorted out as it's a full interior type car, not really a race car per se. In a properly set up car there's little doubt it would improve.
So much like "Crazy Davey's" '67 or John Wilson's '67 when he ran the 496 VP motor. I am not on TC anymore and didn't know if you ran it or not. Thanks.
Difference in the two posted runs was the 1/8 mile 5.97 was a 1.301 60' and the Pomona run was a 1.38 60'
I don't know what their cars weighed (lighter I think) but both were/are far better sorted out on the chassis side for certain. Davey and Dal were wheel standing champions. :)
Feel like going down memory lane? Sure you do, let me help you.......
JW Chevelle 496 781 headed, 959 production block, 10.8 compression 496. 3580-3600 pounds, through mufflers. 9.29 142.29 1.27 60. 615 DA
Crazy Davey 515 CU IN GM 502 block, Foxwell AFR 315 heads, 13.1 comp, Straub hyd roller. 3500 pounds, no mufflers, 9.04 @ 148.00 1.30 60 foot, negative DA.
Yes those were the cars I was thinking, a bit lighter though but still close.
DON'T FORGET YOUR VERY OWN 572 with the 990 heads that you posted from THE 80's!
Like I said, 2 well sorted out cars. (y)
61 - 66 of 66 Posts
