1 - 3 of 3 Posts
Seeing as BG carbs are similiar to the Holleys but not exact, any recommendations on who can convert one from gas to E85? Are the methanol mechanichal pumps that Carter sells compatible with E85? Thanks for any info.
Good luck with that....
IF you find someone to do it Im almost 100% sure that they wont swap the boosters as you cannot buy the BG parts anymore and Holley boosters DONT FIT.
IF they do not swap the boosters and other various parts you will not be getting everything you can get from that Carburetor....which is OK if your just street driving it.
in a race type condition I would want it done correctly.
Mark Sullens E85 Carburetors.
P.S. Ill be in KC this weekend, If your near stop by and Ill tell you in more detail the whats up about the BG stuff.
1 - 3 of 3 Posts
