1 - 4 of 4 Posts
Anyone know of a stainless steel mesh replacement for the P/N 170019 BG element. If not is anyone using the 170019 element with alcohol. I have always thought paper filters and alcohol did not go well together.
Got the filter thinking there was a s/s replacement element available but have been unable to locate one.
When I switched to alcohol in 06,I took out the stock BG filter (left the case there) and just filtered ALL the methanol every time it is put in the cell....works great.
Grant
I do have a small Earl's inline filter on the outlet side so I guess it will have to be the catch all. I will probably remove the element from the BG filter, unless someone comes up with a stainless replacement.
They say the filter is good for gas, alcohol, and nitro on their website. I am going to try E 85 and use it....Tim
1 - 4 of 4 Posts
