1 - 11 of 11 Posts
· T/S 368E
What are you worried about, with that crap engine you have, it'll last for 20 years!!!!!!!!!
· J&E POWER!!
with a 3500lb radial car i went 158 in the 1/8th with a trans-specialties pg 5500, with a 1.80 gearset. switched to a th400, because i kept burning up high gear in the 2speed. o yeah, 648 twin turbo motor.
· T/S 368E
Good, then you won't have any excuses for losing to some heavy antique door car.
Rich got back a day or 2 before New Years, couldn't miss his own party.
If you want, we should discuss getting crossover licenses!!
Later Sam, :p
· Registered
I have pushed mine to a 6.67 @ 208 mph!!!!!!! I think you meant a stock 1.82 gear set.........
· T/S 368E
If I remember he has a good glide.
I took it to mean how much power could a 1.80 hold before needing a Lenco or the next step??
If he put a 1.82 in that thing, I will personally drive over and kick him:cool:
· Registered
Stock case,gearset,output shaft and brake lasted me about 3 years in a 3000 lbs turbo buick.At the time it was running 8.9-8.9`s
Tony
Ran a stock 1.80 low gear PG in a 2800 lb S/St class car for about the same amount of time... but when it blew up, there was nothing that could be saved except the converter/input shaft... No more stock internals after that....
1 - 11 of 11 Posts
