1 - 6 of 6 Posts
any chance of posting a pic. how much are you sprayin. are there any flow problems caused by the 90 elbo instead of the carb to straitin out the flow. thanks for any info you can provide.
I have no elbow. I run a 4 hole throttle body. I spray 150 to 200 on an Induction Solutions plate. I used to run a compucar plate on the efi fuel pressure. That was not good for me. Real hard to adjust fuel pressure without messing up the engine tune and one jet size was way to much change at 40 psi.
Paul
thanks for the info. my engine builder recomended the holly system-max cause i'm not rev'in it very high.
1 - 6 of 6 Posts
