Pull the hood or remove radiator support?
Me being a ford guy, I really figured dynomite.turn it upside down and shake.
I'd say at least the hood anyway. It took you longer to make this thread then removing a hood takes.Pull the hood or remove radiator support?
Lemme guess, another Mustang LS swap?Me being a ford guy, I really figured dynomite.
Never pulled one out of a truck like this, did not know if there was a special trick.I'd say at least the hood anyway. It took you longer to make this thread then removing a hood takes.
And how about just the radiator shroud and/or radiator, instead of the entire radiator support.
Negative, I like Mustangs too much to do that to one. Lol.Lemme guess, another Mustang LS swap?
Cool!Never pulled one out of a truck like this, did not know if there was a special trick.
LS engines are the wonder engine, as I have been told.
125K and its got a connecting rod installed on the outside of the block.
Phuckin' classic Red Green!
LMAO!!!
Sounds like I need to call John Rambo, or maybe the A-Team....You'll need a machine gun. Not to get the engine out. Just because.......
Thank me later.
