1 - 3 of 3 Posts
Should I run a separate line from the compressor housing to each gate?
If I do that one line will be about 4" and the other about 18"
OR would it be best to Install a T off one singe -4 line from the compressor?
These 2 gates are 50mm JGS and I am using -4 Fragola PTFE Line
The compressor currently just has one 1/8" NPT hole drilled in it, but I can easily drill and tap a second hole.
The distances you are describing are not really critical. Whichever way that uses the least fittings, keeps the tubing neat and away from harm would be my choice.
thanks for the reply, I am probably overthinking this like I do most things!
I am just going to mount a T on the first gate closest to the turbo...
1 - 3 of 3 Posts
