1. run your fingers between the straps from the sock to the chute to make sure there not tangled
2.grab each of the pletes of the three sides at the end of the chute and make sure there not inside out.
3.once you have them seperated,lay them down on the ground keeping the straps tight,then fold the sides of the canopy lenghtwise on itself once.
4.starting from the end ,fold the canopy in a zigzag manner roughly the size of the bag width,then place it in the bag
5.place the straps in the bag from side to side until you get close to the sock.
6. load the launchbag in the chutebag ,set the cable and pin until flight...
this is for a air or spring launcher type chute..
