best way to flush a transmission/cooler/convertor
947 Views 3 Replies 2 Participants Last post by  Hutch
I want to change the fluid in the car.
i was thinking of just taking off the line on one of the cooler fittings and running it into a bucket and firing the car up and adding fluid as the fluid is coming out.
anything wrong with that?
i want to flush it all out.
thanks
1 - 4 of 4 Posts
That will work. The lower line is the outlet. If you want to do a real bang up job , take the pan off, clean it all out and change the filter then fill the trans and run 4 quarts or so out through the lower cooler line and it will all be changed and the pan will be clean.
Hutch
Hutch
oh ill do just that.
what filter should i get for it. (hopefully local)
its a powerglide
thanks hutch
It will have a brass screen filter in it now. If your stuck , wash it out. If you can get another it should be a brass screen.
Hutch
1 - 4 of 4 Posts
