What's the best spot to install the vacuum pump suction line to the front of the valve cover or the valley pan, looking for the spot that will pull the least amount of oil.
disagree...had the best luck from the front of the valve cover. Several years ago, tried pulling from valley with a baffle and would suck tons of oil. just moving to valve cover solved it.Valley would be The spot for the least oil.
That's what I am hearing mixed reviews. Anybody else?disagree...had the best luck from the front of the valve cover. Several years ago, tried pulling from valley with a baffle and would suck tons of oil. just moving to valve cover solved it.
Got any pics ?^^^ from the underside?Ours is in the valley cover, we built our own baffle/shield on the under side and will get maybe a few drops.... check it every 3 passes.
No, sorry.
it pretty much looks like a small cup thats cut in 1/2 and weled to the underside. You want the fitting for the vaccum pump as far back into the "cup" as you can.
Hope that made sense.
