1 - 20 of 21 Posts
before clicking on this link make sure your surround sound speakers are cranked up !!!! ....at the 3:15 mark sit back close your eyes and enjoy the onboard sounds as you can almost smell the race fuel and get sensory overload
this is an old 1960's formula 1 motor from BRM ........ (2) flat 8 motors connected together at their cranks by a idler gear producing 600hp with a rev limit of 12k rpm it was called the BRM V16
http://www.youtube.com/watch?v=RBKUQPjQ16I
AW sum!
that motor was only 1.5 litres with a 1.90 bore and 1.95 stroke with 600 hp with less than 100 cubic inch displacement and a supercharger making 74lbs of boost on alchol fuel
This compressor charged 16 cylinder engine from 1951 was competing in Formula One. It is a 1.5 litre engine producing 600 bhp (450 kW).
[edit]Technical data
Designer: Peter Berthon
Cylinders: V16
RPM: 12000
Displacement 1487.76 cc
Power 410.1 kW (549.9 bhp)
Dry sump 50 to 70 lbf/in³
135 degree V16 alloy cylinder block and crankcase. Cast iron wet liners.
Bore 49.53 mm (1.95 in)
Stroke 48.26 mm (1.90 in)
Fuel system Rolls-Royce two-stage centrifugal supercharger with two 3 in (76 mm). SU carburettors. 5.7 bar maximum boost.
Fuel Petrol/alcohol fuel
Ignition Lucas coil, later four Lucas magnetos. One spark plug per cylinder
Valve gear 2 valves per cylinder @ 80 degrees with twin overhead camshafts per cylinder bank, via gear train from the centre of the crankshaft. Hairpin valve springs.
Inlet valves 1.25 in (32 mm)
Exhaust valves 1.09 in (28 mm)
Crankshaft Counterbalanced two piece with 8 plain bearings & 2 main roller bearings. (Later 10 plain bearings.)
In Raymond Mays' book, he claimed the following power curve with the 4.0:1 supercharger (5.7 ata):
100 bhp (75 kW) @ 5,000 rpm
175 bhp (130 kW) @ 6,000 rpm
250 bhp (190 kW) @ 7,000 rpm
335 bhp (250 kW) @ 8,000 rpm
412 bhp (307 kW) @ 9,000 rpm
525 bhp (391 kW) @ 10,000 rpm
585 bhp (436 kW) @ 11,000 rpm
600 bhp (450 kW) @ 12,000 rpm
He also stated that at Albi 1953, Fangio's V16 had a claimed 72 psi boost (4.9 ata) and 585 bhp (436 kW) @ 11,800 rpm. He reached 186 mph (299 km/h).
Discussion Starter · #7 ·
I gotta give it to the beamer!
Discussion Starter · #12 ·
OCIR was the shit back then
Discussion Starter · #14 ·
hell yeah i spent all my off duty time over their when i was stationed at mcas El Toro . i had a 68 camaro with a 427 BBC ,4spd and slicks and with open headers i drove it off the base down sand canyon blvd to the track
Used to go for the match races and Wed night TnT.. What was the guys name with that kite cycle?/
Discussion Starter · #16 ·
yep i was there on wednesday and friday nights but not sure i remember the kite cycle as this was 28 years ago !!!!
ProStock Jackstand Winner
REBUILDING
1 - 20 of 21 Posts
