1 - 10 of 10 Posts
I was hopeing that someone can tell me from experience which is better a blower or turbo? Looking to make 900 rear wheel with small block ford 347, c4 tranny.
Also can you do it with a 10.7 comp. ratio.
Any help?
first off i don't know if i'd push a C4 to 900 horsepower but that's my humble opinion... if this is a street car with 10.7 you could do a turbo with methanol injection when you go racing and you want to turn up the boost... all three power adders are more than capable of what you're wanting to do...
Discussion Starter · #7 ·
I was a little worried about the compression ratio. Do you think meth alone with the turbo will be enough to cool the intake temp?
The car will be used for St. and strip.
Thanks for your help!
well, with 10.7 i wouldn't recommend driving around on the street with 93 octane with the boost up cause that's asking for detonation at one point or another... now, if you just turn the boost up at the track than yea i think the methanol will be more than enough to cool the temperature...
Discussion Starter · #9 ·
I plan on running c-16 and tune with dfi. I don't want to spend money on a fancy intercooler and buy stock in ice machines.
I like the meth idea,but I was told it very corrosive.
you plan on running c16 on the street as well??? the dfi can be very very helpful when it comes to tuning these types of engines... air to air intercooler is another option also
1 - 10 of 10 Posts
