1 - 12 of 12 Posts
· Registered
Edelbrock 2966?
there is no good out of the box sb2 intake. They all are designed to be ported. I have a 048 gm intake that has some port work done to it if you are interested.
· Registered
The largest out of the box will be a 2962. I have a ported version for mine. Ports are 1.55"W x 2.13"H. The older 2862 was 1.25"W x 1.78"H. Can't find the 2866 dimensions but I do know they were smaller out of the box. And then there is the MM t-ram...
· Addicted To Nitrous!
Jeff I have a friend who has a nice one for sale, it has been ported, (cut in half and welded back together) He said he had over 2k in it and would sell it for 1/2 that. He changed over to a sheetmetal manifold and doesnt need it anymore. It is drilled and tapped for a fogger also.
· Registered
Discussion Starter · #8 ·
Thanks Randy. I am putting and F2 on a 399" sb2, so I just need a gasket matched piece. Alot of people are looking for good sb2 intakes, should sell quick.
· Registered
How much, what size are the ports, does it have a large plenum?
ports are 1.500 wide and 2.150 tall, the plenum is decent size but not as large as 617 or 2866. I will take 400.00 for it.
1 - 12 of 12 Posts
