Built an LQ9 based 408 this February with single 88mm S500 in my F-Body. Ran pretty aggressive timing with car while still hot air using C16, assume that's where the head gaskets started failing. Since, intercooled now and has gone 8.70 @ 162. Though that was just last week, felt car had been dropping off and has been pushing coolant for a while now. I was using ARP studs in my PRC heads torqued to 85lbs with moly lube and cometic gaskets. Just tore down and found 5 of 8 leaking! I see many variations of sealing - what would work for street use too? Copper ring in block with MLS gasket? Or steel ring with Graphite gasket? Ring and receiver groove?
I am running 20lbs - looking to go to 24-25 range.
