1 - 11 of 11 Posts
I am having a 555ci. BBC built, and plan on using an f3r with dart 360's. My question is which intake would work best on this combo? I was thinking about a dart, but am planning on going EFI. so would the Super Victor EFI be a better choice? Or would it be benificial to go with a Wilsons, Hogans, or Becks? Any information from the guys out there doin it would be greatly appreciated. Thanks
Ron G.
Class limitations, goals?
The best intake is going to be more along the lines of a Tunnel Ram, advantages include larger plenum volume and more equal runner lengths with a straight shot into the intake ports.
A tunnel ram intake with a bolt on top is ideal as it will make it easier to build a plenum top to accept a larger TB facing which ever direction you prefer. You may hve to have it converted to EFI use.
Of course the down-side of this whole thing is hood height, you'll need lots of it. If you are trying to stay under a stock hood that is going to have a much larger impact on intake selection than performance.
I have a Dart block and heads so figured a Dart intake would be best. They all seem much of a muchness but my reasoning was that the dart intake was probably developed with dart heads in mind.
"Best"? I would look at a custom CFE, Wilson or Hogan sheet metals in that order. Probably in the $2400-$2600 range, but you did say "best".
Thank you for serving..........blessings.......Ron...USMC 1961-1966.
Discussion Starter · #10 ·
Thanks for the info guys, I am not to worried about hood clearance. Gonna have a custom 5-6" cowl made. Those intakes are kinda pricey, but if they make the difference they are probably worth the cash. I was thinking along the same line about the Dart intakes having the R&D done with those heads. Of course my choice of intakes has to go thru the finance dept. (wife)....lol.....but she is being rather easy on me since I am over here.
And Ron......Semper Fi Brother.....USMC 1993-1999....HMLA-367 "Scarface" & MALS-39 "Magicians"......I have done my time down at the "Pen" (Pendleton) too. And thank you for serving sir.
Custom Engine Shop
We use alot of Dart with good luck!
1 - 11 of 11 Posts
