i am really not exactly sure of hp but its gotta be close to 700. The intake i have now i believe is a knock off ebay intake so i am looking to get the best possible intake on the car.
motor is a 468 13.5.1 compression on alcohol. .710/.710 lift cam on installed on a 108 lca. Canfield 310 heads.fully ported with 2.25/1.9 valves.carburetor is a 4150 pro systems carb rated at 1000 cfm.car weighs around 3000lbs with 4.88 gears.
i have a weiand team G intake i could also use but it appears there are better intakes out there.From what i have read on here the edelbrock 454 r or the sniper jr would be the best match , i dont thin they make sniper jr's with 4150 flange, would i still be better off getting a sniper jr and just buying a 4500-4150 adapter plate?
thanks guys
thanks guys
