1 - 20 of 29 Posts
I need a good front strut for my foxbody. I have lakewoods 90/10 with upr coilovers kit.
The double adj will run you @ $490 each just ordered mine last week. thats with out the springs. add another $110 for 14x150 hypercoil springs
Tellin' it like it is
How fast is the car? The doubles are overkill if its slower than low 9s. The single adjustable Strange struts are excellent on a fast street car.
SANTHUFF!
Santhuff struts are great, but the notion of a $1300 pair of struts is a bit of a turnoff to most.
Besides, we've been 5 teens in the 1/8 with $119 Strange single adjustables, so I'd say they aren't a requirement.
I have to tie my front end down almost all the way, so somebody please convince me to spend that kind of coin on a set of struts!!!! BTW I run strange single adjustable.
Santhuffs tighten down wont need the limiters, but sounds like time to get you some dbl adjustable rear shocks to tighten the extension a bit
will that "slow" the bite down a little?
on launch the rear tries to seperate from the frame, the tighter the rebound (also called extension) it absorbs some of the hit/softens the hit on the tire so to speak. more than you can imagine with good rear shocks
Strange single adjustable's are just fine. I know a lot of cars that have dipped in the 7's with them on a 28x10.5..
I run single adj strange on the rear also. I have more of a wheelstanding issue than a traction issue. will the adjustability of the dbl adj rear shock allow me to control the bite by adjusting the rebound on the shock? thus, getting the wheelies a little more managable.
1 - 20 of 29 Posts
