1 - 9 of 9 Posts
Considering a engine diaper .1971 chevelle , stock front frame, big block with 2 1/4" headers. Oil pan is moroso 7 QT with the side kick outs. Oil filter in stock location. Also have oil pan heater as well as a oil temp sender that is attached to oil pan kick out on the same side as the drain plug. Anyone suggest one that forsure fits . Thanks.
Call J&J give them your oil pan number and they can make it fit like a glove. They can also add any provisions that are needed for whatever reason. They will slit the diaper and use velcro to work around objects.
DRE. Dennise is great to work with. Worked his magic on my 72 elky chassis and my BBC.
We have been supplying DJ Safety Engine diapers to YB members for years. Let me know if there is anything we can help you with.
1 - 9 of 9 Posts
