MKIV BBC using standard type bearings (Donovan Block).
What is everyone using these day's?
For most anything you do with a roller cam and babbit bearings you can't go wrong with a teflon coated Dura-Bond bearing. For the most part DB makes bearings for everyone out there. Coating adds protection against dry start.After the engine has sat awhile with spring pressures pushing down on the cam the oil film will get squeased out.
My $.02
Hell, this is a low budget deal for myself. Kind of a swap meet/racing junk special. I can't afford the nice shit!!!Don't you run rollers in all those cup engines?Why make a BBC run any different?
