1 - 2 of 2 Posts
My 700R4 clutches got burnt out so I purchased the rebuild kit from B&M. Since the trans will be out I want to get a stall converter and switch over to a manual valvebody. I would like to know which one is best.
I was thinking about the TCI full manual one...http://www.summitracing.com/parts/TCI-376010/
And then this along with that...http://www.summitracing.com/parts/BMM-80842/
Any help please? Thanks
use transgo reprogram kit if your rebuilding the trans. use probuilt to buy your parts Dana will have every thing you need or i can give you my build its holding 500hp + 150hp nitrous
1 - 2 of 2 Posts
