1 - 5 of 5 Posts
I`m sure this question has be asked a million times, but here it goes how tight should the belt be on a f3r?
side slinger or reverse rotation? if its side mounted about 1/4" after the motor is warm
reversrotation
I think guys run them fairly tight it also depends on what belt you are running
gator cog belt that came with the blower, seems like the engine idles better with the belt alittle loose than tight. i think i heard once that ya needed 1inch of play in the belt. anyone else heard that or have any input?
1 - 5 of 5 Posts
