1 - 10 of 10 Posts
after reading the "Max boost/rmp with a rib belt Vortech? " post i think maybe i have went the wrong way in pullies.
i have a 331 with an s-trim 8 rib belt but i can only get 10-12#, thought maybe the blower was just running out of steam but maybe i have more belt slip than i thought.
i have a 2.50 pulley. I've already talked with vortech regarding the t-trim upgrade and i should be sending it off in the next couple weeks.
what do you guys think?
Many times belt dust is evident when it slips. Do you see any dusting?
yes, the front of the charger has alot "dust" on it.
you the same BlownShovel from turbomustang?
With a narrow belt, small pulley it's tough to keep traction. Yes Mike?
ok, might try a bigger pulley for shits and giggles before i send this thing off. i swore the "boost bug" wouldn't catch me but here i am looking for more...lol
yea, Mike..... i got a carb and a hat from you a few years ago.
Boost is addictive... then you start breaking stuff ;)
Any chance you can add more wrap around the head unit pulley? An extra idler can help quite a bit by wrapping the belt around the pulley for additional grip area.
Discussion Starter · #8 ·
i can try that. i know each combo is different and this head unit is to small but i thought i should have more than 10-12#'s(maybe not)
combo is 331, afr 205 and a big blower cam.
The larger cam and decent heads can be part of the blowers struggles to push 12psi. And it may start pushing a bunch of hot air to reach that goal. Boost is a measure of resistance. Get the blower upgraded and it'll push the 10-12psi you are looking for.
1 - 10 of 10 Posts
