Is it lower than the fuel cell? Belt driven pumps need to be gravity fed.
For initial priming, remove the fuel inlet line to the pump, and blow compressed air into the fuel cell vent. When you have fuel, re-attach the fuel line.How many tries does it first take you guys to prime the pump.... this one is new from aermotive and doesn't want to seem to want to prime at all.... 5th attempt and yes it clocked the right way. just no fuel pressure.
:smt021 Ouch.i got it all worked out, it was a badfuel pressure guage on reguator, the indash guage was reading 55psi....
did manage to hydrolock the motor with a cracked cylinder head and bent some stuff int he motor.
