Curious what you guys think. About a month or so ago my oil pressure dropped about 10lbs. Pulled the main and rod bearings and had one spun main bearing. So we just rolled in a new set that was the same brand and size. The crank looked fine in that spot. Never pulled heads or front cover, etc.. Drove the car the last month with good oil pressure and after 5 passes it's doing it again. I am suspecting a bearing failure again. I realize I am pushing this engine to the limit and it may be as simple as that.
This time I will pull the crank and have it checked. If the crank is not bent I am wondering what issue might be causing this. The only thing I can think of is I run the stock flywheel and I dremel out the holes for my convertor to fit. I would think as long as it the snout is fitting in it shouldn't be an issue. However, since I have done this again after only a months driving and 5 passes I am wondering if I should get an aftermarket flywheel.
Its a stock 6.0 out of a 2005 denali. I run twin SW366's on E85. My last pass was friday and it went [email protected] leaving on 4lbs of boost. Yesterday I tried to leave on 9lbs and that was when I noticed my oil pressure was lower. Today I started it up and it was still about 10lbs lower even cold. Car sounds and runs fine. fwiw
