1 - 3 of 3 Posts
Hi guys
36x17.5 / 16 Slicks
The width of the tirebead is 0.95in ! widest I've seen.
The internal width of the beadlocks is only 0.55in
The beadlock studs are way too short to get this started to clamp, and even if so, this is way more clamping than we are used to.
This is a new double beadlock billet cone wheel from Weld and a Goodyear tire.
Any tips or tricks up your sleeves?
Call Weld and ask for someone in application engineering. Short of making a custom ring I doubt there is a way to run that tire on the current wheels. That would be my first step anyway. Hope this helps.
I wonder if that tire is meant to be used with the bladder?? I think that’s what it’s called it goes inside the tire and clamps the tire against the rim without beadlocks Tim McAmis did a video on it I believe
1 - 3 of 3 Posts
