1 - 4 of 4 Posts
looking at a 315/60/15 drag radial like the hoosier or m/t
also i have heard they work awesome the 30x10.5 hoosier radial slick
and ive thought about a 28x10.5 stiff bias slick
mustang mini tubbed im using a glide with tbrake
i like the idea of the radial ,not having to run tubes or screwing the rims ,and the idea of the stability they offer but im not sure for this class its headsup out of the gate on pro tree .400
If you are running an index class, I would recommend a bias ply slick. The diameter will depend on your gearing and fitment. For index/bracket racing, the taller the better.
Thanks,
Jason Moulton
If you had planned to run the P315/60R15, you may want to consider a 29.5/10.5-15S, spec # 3062S. It is very similar in size but it will grow at speed.
Thanks,
Jason Moulton
1 - 4 of 4 Posts
