1 - 7 of 7 Posts
I have a 466 BBF with ported to the max procomp aluminum heads and all the good stuff in them, Comp Cam 306-306
262-262 @.050
Valve lift 640-640 1.7 Rocker arms. SpeedPro dome pistons, Hbeam rods BIG tube headers, 1150 Dom carb, 4000 or so stall, C4, in a fox body mustang coupe.
Took the car out with a little 150 shot and on a real bad pass on foot brake went a 10.40. Ran out of nitrous so went home. I put a NOS dubble cross bar big plate on the car and took it back out and everything working well it only went a 10.20 at at 130mph. on a 250 shot..??? I reset the timing etc. What are you guys setting your fuel pressures and timing on motor and on spray at? Im still learning as I go. What do i need to change/do to get this thing dialed in..?? Thanks guys!!
are you blowing through the convertor? Like bruno ask, what did run on motor. Seems like the car should in the 9's with a 250 shot.
11.20 on motor, 3300 lbs with me in it 114 fuel 6lbs on nitrous side and 5.5 on motor side. 150 single bar plate and small noids it ran a 10.40 on a bad pass..
i would think your car should be faster even on the motor. my first motor in my fox was a 466 with less then 10:1, .605" cam, stock ported iron heads, victor intake with 850 carb and nos cheater plate system. went 11.20s-30s on motor at 121 mph when i first ran it, then 10.30s at 130 on 150jets, and 10.30s at 133 on 210 jets. i found that the convertor was way too loose for the setup(especially since i only shifted it at 6k). after i changed the convertor to something better suited to the setup, it went a best of 11.14 at 124 with a glide at 3600lbs on motor and 10.30s at 133 on 100 ish jets(56/56)
Discussion Starter · #7 ·
Think I got it figured out.. we looked up nitrous jetting for the dubble cross bar and I guess it HAS been updated.... With 44-45 jetting I was only spraying maybe a 150 shot again... For a 225 shot its calling for 51 nitrous and 61 fuel... I put the 44s and 45s in by the book I got with the kit. SO I dont know what the prob is there..??? So everything I am doing so far is correct for me to be in the 9s. Just have to get the right jets in it.. LOL!
1 - 7 of 7 Posts
