1 - 13 of 13 Posts
**BOOSTED SBF***
Does anyone know the part number for the MSD Billet Crank Trigger style Distributor? The one I was using is the low profile model and it doesn't clear the new cast manifold that we converted to EFI. It worked fine with the Hogan manifold but it's way to short for the new manifold. I don't see a listing for one that is not low profile and still designed to work with a crank trigger. I'm sure this is a stupid question but will the standard billet model work in this application?
The Enemy
Yes, it just needs to be modified.
I went from this distrib to the low profile like you have. Had to machine my intake down for it to fit though. Also had to run the cam sync off the belt drive.
**BOOSTED SBF***
Do you have a picture of the mods you made on the manifold or of it installed on the motor? That may be a better solution for me too. Thanks
**BOOSTED SBF***
We are running gas and have been talking about different ways to cool the motor but havent decided for sure yet. What mods did you do on the other distributor?
1 - 13 of 13 Posts
