1 - 12 of 12 Posts
Discussion Starter #7
cam specs are
lunati part# 40119912
lobe seperation 114
ex closes 41.0 atdc
ex opens 89.0 bbdc
in opens 30.5 btdc
in closes 78.5 abdc
valve lift
in 0.823
ex 0.791
1.7 rockers
duration @ .050
in 289
ex 310
advertised duration
in 324
ex 348
would post a pic but my photobucket is messed up at the moment. DOH!
Discussion Starter #8 (Edited)
^^^^^^ those are the wrong specs, thats my blower cam... whoops. admin. please delete, it wont let me after 5 min of posting
here it is i got my photbucket working
I run something similar in a BBF twin 88. Less lift though.
A little hard to spool with a tight converter so I've had to advance 4 degrees. If I was to redo I would try to move the power band down a bit and hope to gain torque at 3000rpm. That gets you over the hump.
1 - 12 of 12 Posts
