1 - 19 of 19 Posts
RED ROCKET
depends on head and cam...only way to know is to try it..i would think a little higher would help.
On a dyno with a 32 jet my 588 make peak power at 7400. That is with out of the box 355 dart heads and a cam that is not radical.
582 cid aluminum Brodix 9.8 short deck Brodix 1802 heads single PS SV1 carb RM Erson n20 camshaft 117 lsa 500 HP over 2 foggers...spin it to 7600 on 1-2 shift & cross at 1/4 at 7800.
"Made" Member
did you ever try short shifting at 7000? with my last combo it seemed to go faster shifting at 7000...
This is our first time out with the 582 in the 2002 Camaro...we previously ran it in the 71 Camaro, which is almost 1000# heavier. The engine & tranny combo seem to like it shifted at about 7400.
"Made" Member
Discussion Starter #8
pretty car...
Thanks Outlaw...wish someone would find the '71 (see below) just as pretty...got to sell it...the "Mrs." says 3 racecars is a bit much...LOL.
friends 69 chevelle on big spray(7.40's)with full kill mode shifts between 8500-8800....depends on your combo, and your goals. whats your full combo, others can help more if u list your exact combo
My 540 with a a big pill was still climbing at 8500, but I can't bring myself to shift there on purpose. However a few times when the elec shifter didn't work it has seen that rpm. Lol. I've been shifting it at 7500 for 2 years now.
"Made" Member
Discussion Starter #12
My new combo isnt done yet. Was just curious how high you guys were spinning them...
peak hp is 7400 rpm I shift at 7600 rpm. This is a 4.25 stroke 555. I bet the average hp is a lot better from say 6500-7500rpm than 6000-7000rpm even on the jug.
"Made" Member
Discussion Starter #16
from the looks of everyones posts im gonna be trying 7500rpm first...
TRZ Rocks!
Nitrous makes such a flat torque curve, there doesn't seem to be any big gains running them way up on the shift. A g-meter will tell you if you are going too high or too low (that was for you Fofo)
if u know where u peak at in your rpm range(when spraying it will be lower rpm typically than when n/a), try shifting at your peak hp. then try a few hundred higher and keep experimenting on same day at track til u slow down
Thx Kevin for keeping me "focused"...I needed that.
1 - 19 of 19 Posts
