1 - 12 of 12 Posts
i run those type heads do not know about that number mine are 15 degree with a sheetmetal intake.they could be some old prostock heads
These are the same casting number heads I have. I've been searching for a intake for them with no luck. single car,dual carb or stack injection I will take anything. My heads are ported to use the FelPro 1249 intake gaskets. Any leads on where to find one would be great.
Fel Pro 1249 - Fel-Pro Intake Manifold Gaskets
Fel Pro #375-1249
H/P Intake Gasket Big Block Chevy
Pontiac Super Duty/Brodix Heads
Gasket Material: Composite W/Coating
Port Size: 1.90 x 2.70''
Thickness: .060"
$19.99 Ships Monday
If you find a lower price on a item we will match it
The priced matched item includes "to your door" costs
How to Price Match
XXXX.XX Skip Price Match
Click for JEGS Online Price Match
Go Phuck youself
Thanks for the link!
i have a brand new set of pontiac pro stock heads 18 degree if you wanta see pixs of unmolesed heads lets me know and pixs of a sheet metal intake not hard to make if you wanta learn to weld alum. or maybe you already know how, aint that hard so you have to learn no biggy if you wanta race then the bug has bitten you and you will learn.
1 - 12 of 12 Posts
