I bought a 78 Camarillo a couple years back to toy around with while rebuilding my Chevelle.Car has got a 468 bbc 10:5:1 compression Keith black Pistons stock steel crank 781 casting heads I don't have the specs on the cam handy but it's the biggest hydraulic flat tap pet cam that I could get aluminum dual plane intake with a demon 850 carb and Msd ignition. 400 turbo trans with a coan hot rod convertor 410 gear with a 28" tire. Cars got 3 inch exhaust with flow masters sounds great however doesn't really have no balls. I think for starters the dual plane intake has got to be switched to a single and I've also been told to replace carb with a quick fuel. Ok from the guys that know what their doing what's the problem and how much affect does the hot rod ( or maybe the called it a pro street convertor) have on the car. Thanks a lot Gentlemen for any help/advice
