1 - 20 of 38 Posts
for 2500+hp combos what are the good aluminum blocks to go with?
how about billet? or cast aluminum?
i see alot of century blocks but are there others that are just as good?
On the flow bench
i know u said alloy....
the west australians are still using dart cast iron blocks, and irun deep into 5.7's
72% max OD , d series screw
4.4 lbs / cube
http://www.youtube.com/watch?v=_gDpYV2yCO4
Eleven years on this Arias New Century block.
Not a racer but I have put hundreds of hours on it and many hundreds of WOT runs at the 1800 hp level.
IMO a Y block is all around a stronger design.
Charlie westen makes an extremly nice aluminum block that can be used with jesels cam catridge system awesome setup for max effort build. I believe its on a 5.3 bore spacing
Discussion Starter · #13 ·
4.4 lbs / cube
i got a big m now but the nose is just so damn heavy. i can get it profiled and lose 32lbs but rather lose 140lbs.
is anyone a dealer to help out on the cost of any of these blocks?
You putting a wheelie bar on the car?
Discussion Starter · #15 ·
no. i love the radials. im so nose heavy that pulling a wheelie off the line is just about impossible.
New century or Rodeck either way you can't go wrong. Just missed a 10.2 Rodeck last week for 1500 bucks. 2 year old block. Friend in Socal has one in his alky injected supercomp dragster. Block was made in 1996. Only on it's 3rd set of sleeves.
Discussion Starter · #17 ·
has to be a 9.8 deck. is a good deal for sure.
Rodeck does short decks too. If you can find one.
Have had a New Century in the past , one of the few parts I have bought that was actually ready for service after it was washed . Very nice piece .
Discussion Starter · #20 ·
1 - 20 of 38 Posts
