1 - 12 of 12 Posts
Kelly's Nightmare
What should i expect to pay for a 4 link and back halve in a 4th gen f-body?
For parts or parts and labor? I'd imagine over 10k to have someone do it. It's cost me 200.00 to mini tub my 4th gen Camaro myself, people charge 1500-2000 with labor for mini tubs so you can see the labor is going to kill you.
I'm doing a full tube frame myself, depending on where you get your parts and what deals you find will vary your price a lot. Obviously you can find good condition used rims and sometimes with new rims and new tires for 1/2 the price, same thing with rear ends and stuff, depends on what you can find to make it work, brand new everything from a dealer gets expensive.
7.86 @ 8800DA 3365lb 275s
What about rims and tires, rear end, and rewiring stuff in the hatch area? A rear end alone with brakes will run at least 2600-2700. Rear rims and tires will be over 1,000.
that's true mine doesn't include that stuff (does include a rearend housing) but i wasn't sure he was asking about eveything or just for the backhalf and 4link.
Kelly's Nightmare
i am just looking at the cost of the 4-link and back half i have a 9" that can be narrowed more for clearance and a set of wheels and tires.
i'm at $2500 plus parts that's where i start
Around here you can get a moly 14 point cage, frame connectors, reinforced torque boxes and mini tubs done for about 4/5 grand in a Fox body stang. In front of or through the dash makes the difference in cost. RM
Frame and Rear end Labor about $1500- $2000 plus parts
Tin work depending on material and how much of the car you want cut away $1500-$2500 plus material
Battery mounts Fuel cell mounts fuel pump mounts ect.. $400- $800 plus parts..
Those are Oklahoma Prices
Here is my price in southern Illinois
Basic back half pricing
Round tube 4-link welded rear subframe package, includes:
Fabricate frame clip from 1.625"x.134 round tubing
4 link brackets installed
rear driveshaft loop installed
frame connectors
upper shock crossmember with shock mounts installed
heavy duty 1.250x.095 moly 4 link bars with left & right tube adapters
chrome moly 3/4x5/8 left and right rod ends in 4 link
strange or QA1 single adjustable coil overs and springs
bolt on diaginal link with 1/2"chrome moly rod ends
Adjustable lower shock mounts
battery box/mount
fuel pump mount (Cust supplied pump)
5 gal plastic fuel cell
fuel cell mounts
10 point mild steel roll cage, with seat belt tabs
install aluminum wheel tubs and aluminum floor behind main rollcage hoop
labor to install frame package, includes:
cutting out of old floor and wheel wells
aligning and welding in new subframe to rear panel and rockers
tie in with frame connectors to front subframe
fab 9" mild steel housing, fully braced and bracketed, includes:
New Moser axles 31, 33 or 35 spline (your choice)
fully welded back brace
new housing ends
large filler cap
drain plug
extra gussets and bracing
total for above $7500.00
some options
Moly Cage Add $1500.00
Wilwood or aerospace rear disc brakes installed Add $475.00
plum brakes (includes steel lines and braided flex lines) Add $200.00
60" Wheelie Bars Add $600.00
Chute mount Add $250.00
Anti rollbar Add $350.00
Purple Hayes Performance
Herrin, IL. 62948
www.purplehayesperformance.com
1 - 12 of 12 Posts
