1 - 20 of 35 Posts
Administrator
:smt013 :smt013 :smt013
I get this error when I try to access the Microsoft Doc. file..!! Can you cut and paste them here please?
Monty Mikho, you do not have permission to access this page. This could be due to one of several reasons:
Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation
NMCA-EDELBROCK SERIES
SUPER STREET 10.5W - 2006 RULES
Preliminary Version 1.0, Nov 2., 2005
General Overview
Super Street 10.5W vehicles are the fastest and quickest vehicles in the NMCA series designed for stock bodied vehicles. Super Street 10.5W entries are permitted small block and big block engines up to and including a maximum of 740 ci depending on combination, and compete on a 33x10.5”W” tire. Single power adder supercharged, nitrous oxide, or turbocharged engine combinations are permitted. Super Street 10.5W class is for 1950 and newer American production cars and trucks. Super Street 10.5W racing will be conducted at all drag racing events (see race schedule).
Qualifying Information, Ladder Type, & Tree
All Run, NHRA Sportsman Ladder, Pro .400 tree, Heads-Up.
Weight Guide:
Small Blocks
Nitrous 440 2400
Nitrous 525 2550
Naturally Aspirated 525 2200
Supercharged 440 2800
Single Turbo, 106mm 440 2950
Twin Turbo, 88mm 440 3050
Big Blocks
Naturally Aspirated 650 2400
Naturally Aspirated 740 2500
Nitrous 650 2800
Nitrous 740 3000
Supercharged 550 3000
Single Turbo, 106mm 550 3050
Twin Turbo, 88mm 550 3100
Weight Adds/Deducts:
Clutch-equipped transmissions add 150 lbs
Nitrous combinations with single carb. deduct 50 lbs.
Entries with non-stock firewall or non-complying front suspension may compete with additional 100 lb. weight adder.
Maximum cubic inches for all combinations - 740 CI.
*If actual cubic inch is more than base cubic inch listing, there will be a weight penalty of 8.0 pounds per cubic inch assessed to base weights, up to the maximum cubic inch permitted in the class.
Note: All weights are with driver & rounded down to the five pound increment. Ex: A calculated weight of 2842 would be required to weight 2840 with driver at scales.
Accepted Products:
As of January 15th for each racing season, the NMCA sanction will no longer accept formal requests from manufacturers to have new products considered for addition to current-year accepted lists. As of 1/15/06, NMCA will consider manufacturer requests for new products for the 2007 season only.
1: ENGINE
1.1 COOLING SYSTEM
RADIATOR: Radiator is required.
Water pump: Any aftermarket (belt drive or electric drive) pump permitted.
COOLING FANS: Any permitted.
1.2 Engine
ENGINE: Engine must be a V-8 automotive type engine. Any internal modifications are permitted. Cross breeding of an engine to a different make of body permitted. Engine swapping permitted during event. Big block and small block engines are limited to a maximum of 740 cubic. Only a single power adder is permitted.
Water injection is prohibited.
1.3 Exhaust
EXHAUST: Any exhaust permitted.
1.3a) HEADERS & COLLECTORS: Any headers and/or collectors permitted.
1.3d) MUFFLER REQUIREMENTS: Mufflers are required. Any type of collector mufflers are permitted.
1.5 FUEL-DELIVERY SYSTEM
DELIVERY SYSTEM: All fuel lines must originate and return to a single, non-segmented, fuel cell or OEM fuel tank. A valve for removal of fuel (gasoline) during technical inspections is mandatory. Aftermarket/fabricated fuel tank or cell permitted.
1.6 GASOLINE
GASOLINE: Gasoline is the only acceptable fuel for use in this eliminator for the specified combinations The NMCA Racing Association reserves the right to check gasoline at any time during competition. Failure to pass fuel check is grounds for disallowance of the run during competition and disqualification from the event during eliminations.
1.9 NITROUS OXIDE
NITROUS OXIDE: Nitrous systems up to 3 stages are permitted. Push systems prohibited. The use of agents other than nitrous oxide as part of, or mixed in, the system are prohibited. Nitrous oxide may not be used in conjunction with any other power adder. If entry is entered as a non-nitrous entry, all solenoids, lines, fittings, and bottles must be removed prior to technical inspection and any competition runs. Nitrous oxide systems must use gasoline only for the fuel enrichment circuit.
1.10 OIL SYSTEM
OILING SYSTEM: Wet sump or dry sump oiling system permitted. External oil pumps permitted. Any vacuum pump and/or evacuator system (header, or otherwise) permitted. Any oil pan permitted.
1.12 SUPERCHARGER
Any single centrifugal superchargers permitted.
SINGLE CENTRIFUGAL SUPERCHARGER: Any single centrifugal racing supercharger permitted. Injection of any liquid, gas, or any other substance into the inlet or exhaust housing prohibited. Supercharger compressor wheel must be constructed of cast or billet aluminum. Exotic material wheels prohibited.
1.12a) BLOWER DRIVE SYSTEM: Belt-style or Chain drive system permitted. Fuel and/or oil lines must be shielded wherever they pass the supercharger drive belt. Either a belt guard or fuel/oil line guard may be used. Chain driven supercharger permitted only with SFI approved chain shield.
1.15 BLOCK
Block: Any commercially available engine block is permitted, cast iron or aluminum. Maximum cubic inches is 740 CI for all combinations.
1.16 ENGINE LOCATION/MOUNTS
Engine Location/Mounts: Block and/or heads must not touch stock firewall or cowl area.
1.17 HEADS
Heads, GENERAL: Any cast aluminum or cast iron heads are permitted. Billet heads prohibited. Cylinder heads must be overhead valve single spark plug per cylinder design. One-off or custom made cylinder heads prohibited.
1.18 VALVETRAIN
VALVETRAIN: Any permitted.
1.19 CARBURETORS
CARBURETORS: Any combination is permitted two four-barrel carburertors with no weight adder. Split carburetor permitted (example: a Dominator, split and offset into two two-barrels).
1.20 FUEL INJECTION
Fuel Injection: Fuel injection must be electronic. Fuel-injected entries will race at the same weight as carbureted entries.
1.21 INTAKE MANIFOLD
INTAKE MANIFOLD: Any intake manifold permitted for all combinations.
1.22 SOLENOIDS
SOLENOIDS: Any amount or type of solenoids permitted.
1.23 TURBOCHARGERS
Turbocharged engines are limited to a single 106mm turbocharger or twin 88-mm turbochargers. (tip-to-tip measurement). Housings may be modified (i.e. slits in the housing). All turbocharged entries are limited to small block Ford engines. Injection of any liquid, gas, or any other substance into the inlet or exhaust housing prohibited. Turbocharger compressor wheel must be constructed of cast or billet aluminum.
1.24 AFTERCOOLER/INTERCOOLER
AFTERCOOLER/INTERCOOLER: Permitted
1.25 POWER ADDERS
POWER ADDERS: Any single power adder (nitrous oxide, supercharger, turbocharger) permitted with engine combination. See sections 1.9, 1.12, & 1.23.
1.30 BOOST CONTROLLERS
BOOST CONTROLLERS: Electronic or automated boost controllers permitted on turbocharged applications only.
2: Drivetrain
2.3 CLUTCH
Vehicles equipped with clutch add 150 pounds.
2.4 DRIVESHAFT
Driveshaft: Any permitted.
2.11 REAREND
REAREND: Any automotive type rearend permitted.
2.12 CLUTCH-EQUIPPED TRANSMISSIONS
MANUAL TRANSMISSION: OEM or aftermarket transmissions with a maximum of 5 forward speeds permitted, including "clutchless" models. Entries so equipped will add 150 pounds.
2.13 CONVERTER-EQUIPPED TRANSMISSIONS
Any OEM automatic or purpose built manual transmission (i.e. Bruno, Lenco Drive, etc.) with a maximum of 5 forward speeds utilizing a torque converter permitted. Manual, Pneumatic, electric, and hydraulic shifters prohibited.
3: BRAKES & SUSPENSION
3.1 BRAKES
BRAKES: All cars must have front and rear hydraulic brakes. Automated brakes or any type of traction control is prohibited. Application and release of brakes must be a function of the driver’s foot. Line loc permitted on front wheels only. Any other electric, pneumatic, or hydraulic device in the system is prohibited.
3.2 SHOCK ABSORBERS
shock absorbers: each vehicle in competition must be equipped with one operative shock absorber for each sprung wheel.
3.4 SUSPENSION, general
SUSPENSION, GENERAL: This eliminator is designed for “Back-half-type” chassis, with stock front clips, stock front frame rails, and stock type front suspension. Complete stock front frame rails from the firewall forward must be retained. Front frame horns may be modified for fitting of removable front end.
FRONT WHEEL DRIVE CONVERSIONS PERMITTED IN THIS ELIMINATOR.
3.4 Suspension, FRONT
FRONT SUSPENSION:
3.4a) K-MEMBERS: Aftermarket K-Members permitted. K-member may be modified in oil pan area to allow oil pan enlargement or removal.
3.4b) STRUT TOWER/UPPER SHOCK MOUNTING POINTS: Factory OEM strut tower required. For 1978 & earlier model years, OEM strut tower/shock tower may only be removed in lieu of installing/using commercially available suspension kit (i.e., Heidt, Fatman, etc). Other sections of front suspension rules must be adhered to. Modifying of strut or shock towers allowed for header and engine clearance only. Must retain at least 50% of the original tower. Top plate may not be modified except mounting holes may be moved.
3.4c) CONTROL ARMS: OEM or tubular stock type control arms permitted in stock location. All vehicles manufactured with four control arms must retain four functioning control arms.
3.4d) SHOCKS/STRUTS: Aftermarket struts and shocks permitted in stock location.
3.4e) SPRINGS: Aftermarket springs permitted.
3.4f) COIL OVERS: Coil over shocks and struts permitted.
3.4g) CAMBER/CASTOR PLATES: Bolt on type camber plates permitted.
3.4h) SPINDLES: Accepted, bolt-on, commercially available aftermarket spindles permitted.
3.4 SUSPENSION, REAR
SUSPENSION, REAR:
3.4) Stock-type, 4-link, and ladder bar rear suspension permitted. Panhard bars, track locators, sway bars, and torque arms are accepted. Any rear shocks are permitted.
3.6) WHEELIE BARS
WHEELIE BARS: All wheelie bars must have a non-metallic wheel. Wheels must turn freely at starting line. Wheel preload is prohibited. Using the wheelie bar as a “fifth wheel” sensing device is prohibited. Hydraulic, pneumatic, electronic, etc. or any other adjustment or movement during run is prohibited.
4:FRAME
4.4 FRAME
FRAME: Stock, unaltered frame rails required in front subframe. Rear subframe may be moved in or “C’d” for tire clearance and suspension components.
4.5 GROUND CLEARANCE
GROUND CLEARANCE: Minimum 3 inches from front of vehicle to front axle; 2 inches for remainder of vehicle, except oil pan and exhaust headers.
4.12 WHEELBASE
WHEELBASE: Entries must retain stock wheelbase + or - 1 inches of stock. Maximum variation from left to right and front to back of 1 inch.
5: tires & wheels
5.1 Tires
TIRES - FRONT: Front tires must have a minimum tread width of 4.5 inches.
TIRES – REAR: Street type or racing slicks required. Vehicle must be equipped with approved tires. Acceptable sizes include those stamped 31x10.5W, 33x10.5W, 29x10.5, or smaller. Maximum measured tread width at all times is 12.0-inches, and measured circumference is 104.0 inches. Tire width will be measured by a “go-no go” gauge after conclusion of run at scale area. Tire tread may not extend outside fenders. Tire shaving is prohibited.
5.2 WHEELS
WHEELS: Spindle-mount front wheels permitted.
6: INTERIOR
6.1 INTERIOR
Interior, GENERAL: Must maintain stock appearance; including factory OEM-look dashboard. Master cylinder may be relocated to accommodate brake pedals & linkage.
6.4 CARPET
CARPET: Floor and tunnel where visible must be upholstered, carpeted, painted or anodized.
6.5 SEATS
SEATS: Single driver seat must be in stock location and the centerline of the driver’s shoulder must not sit behind the plane of the door jam.
6.6 DOOR PANELS
DOOR PANELS: Stock OEM or replacement door panels required.
6.7 STEERING COLUMN
STEERING COLUMN: Aftermarket steering column permitted. Removable steering wheel permitted.
6.8 GAUGES
GUAGES: Aftermarket gauges may be installed in factory or OEM style dash.
6.9 PEDALS/PEDAL LOCATION
PEDALS/PEDAL LOCATION: Aftermarket pedals and linkage are permitted, but must remain in stock location in foot well.
7: Body
BODY: Vehicle must retain original appearances and profiles for year and make of body. Only 1950 & newer American production vehicles permitted. Factory quarter panels, factory pillar posts, door jambs, and roof required. Lightweight body panels restricted to: front end/fenders, doors, hood/scoop, bumpers, and trunk-lid/hatch/deck-lid. Doors must be OEM appearing, have a functional door latch, and must function in OEM-style. Fiberglass fenders must be bolt-on replacements and have OEM appearance and function. Carbon Fiber is an acceptable lightweight substitute for Fiberglass. One-piece front ends (fenders and front valance/bumper) are prohibited. Driver and passenger doors must be functional and operable from inside and outside of vehicle. Front fender opening dimensions must be OEM stock. Hood and/or trunk lid must be hinged or lift off. Hood, doors, and trunk lid must be attached separately and must be operable. One piece front ends (fenders and front valance/bumper) are prohibited.
7.1 ADVERTISING
GRAPHICS: Graphics (for advertising or creative purposes) permitted on entire body, including doors, hood, rear quarter panels, front fenders, spoiler, etc.
CONTINGENCY DECALS: In order to be eligible for NMCA official contingency program, all contingency decals are required to appear rear of door jam (B-post) on the rear quarter windows, rear window, or body in a clear and organized fashion. Contingency decals may not be overlapped or modified. Other decals and sponsorship (non-contingency) may appear on bodywork, front end, and on windows.
NMCA REQUIRED DECALS: The following decals are required for competition in NMCA events.
NMCA Windshield Decal – must be installed on top of windshield. This NMCA decal must be the only decal on top of windshield. Other vehicle sponsor decals may be placed at base of windshield.
NMCA 2006 Drag Racing Series “Side” Decals – must be installed on each side of vehicle on quarter windows.
Class Sponsor Decal – class sponsor decal must be installed on base of windshield on the passenger side.
Permanent Numbers – permanent numbers are required for competition in this class.
7.2 SPOILERS
Rear SPOILER: Rear spoilers permitted. Rear spoiler may not be molded into body (Pro Mod Style).
Spoilers must be stationary during entire run.
7.5 FIREWALLS
Firewall: Stock firewall required. Firewall may be notched for clearance for bell-housing, distributor, blower, or intercooler. For Chevrolet Corvette, only if OEM equipped with stock fiberglass firewall; firewall may be replaced with a flat steel firewall, no thinner than .024, located in the OEM stock location. Replacement steel firewall must be one piece, fully attached along perimeter, and permanent in nature.
7.6 FLOOR/TRUNK PAN
FLOOR: Floor/ trunk pan/transmission tunnel modifications are permitted.
7.7 HOOD/SCOOP
Hood/Scoop: OEM, fiberglass or carbon fiber hood and/or scoop permitted. Forward-opening or rear-opening scoops permitted. Hood must not be part of front fenders. Scoop need not be part of the vehicle hood. 7.9 WINDSHIELDS/WINDOWS
Windows: O.E.M. safety glass or Lexan permitted.
7.10 BUMPERS
Bumpers: Front and rear bumpers must be duplicates of originals and may be made of any light weight materials. License plate frame holders are not permitted to extend beyond flat surface of front bumper. No body components, bumper add-ons, or body kits are permitted to be added to the vehicle with the intent of increasing the frontal distance of the bumper for the purposes of breaking the infrared beams.
7.11 FENDER SPLASH PANS
Fender Splash Pans: Full, factory OEM or aftermarket inner fenders required. May be trimmed for header clearance.
7.15 DOORS
Doors: Driver and passenger doors must be functional and operable from inside and outside of vehicle.
7.16 AERODYNAMICS
AERODYNAMICS: Taping of any body parts, seams, or front end prohibited.
7.17 BODY KITS
BODY KITS: Accepted, commercially available body kits permitted.
7.18 COWL AREA
COWL AREA: Cowl area of vehicle must be unaltered except for modifications necessary to install aftercooler/intercooler equipment.
7.19 FRONT FENDERS/FRONT FASCIA
FRONT FENDERS/FRONT FASCIA: Stock appearing front fenders and stock appearing front fascia required.
8: Electrical
IGNITION: Any battery operated ignition permitted. Any distributor drive system permitted.
8.5 STARTER
STARTER: All entries must be self-starting with on-board starter.
9: SUPPORT GROUPS
Bracket racing aids such as optical sensors, delay boxes, stutter boxes, etc. prohibited. Throttle stops prohibited. The application or use of any device, mechanical or electronic, that permits the driver to ascertain the position of their vehicle in relation to the starting line is prohibited.
9.8 TOW VEHICLES
TOW VEHICLES: Vehicles may be towed in or to staging lanes and the return road.
10: DRIVER
10.4 CREDENTIALS
CREDENTIALS: See general regulations.
11: CLASS & SAFETY REQUIREMENTS
It is the participant’s responsibility to familiarize oneself with the class requirements as found in the 2006 NMCA rulebook and the safety requirements as found in the 2006 NHRA rulebook.
The participant agrees that the participant bears the ultimate responsibility at all times to ensure the safety of participant’s vehicle and to ensure that participant complies with all applicable NHRA & NMCA rules. The participant agrees that participant is in the best position to know about the construction and operation of participant’s vehicle, equipment, and clothing, and whether there has been compliance with all applicable NHRA & NMCA rules.
12: Street-Legal Requirements
NOT APPLICABLE
13: TRUCK GUIDELINES
1. Bedcovers permitted.
2. Tailgate must be closed during competition.
3. Fullsize and compact pickups permitted.
4. El Camino-type vehicles must participate under passenger-car rules.
5. Rear-window glass may be replaced with Lexan for the purpose of accepting rollcage bracing that extends rearward from the cab.
6. Accepted modifications permitted to allow removal of bed from frame without removal of roll bar or roll cage bracing.
14: RULES ADJUSTMENTS, MID SEASON LOG
Date: Adjustment:
None at this time.
Should read. Remember these rules are preliminary, so if anybody would like a change or adjustment, post it here or PM me.
1.23 TURBOCHARGERS
Turbocharged engines are limited to a single 106mm turbocharger or twin 88-mm turbochargers. (tip-to-tip measurement). Housings may be modified (i.e. slits in the housing). All turbocharged entries are limited to small block engines. Injection of any liquid, gas, or any other substance into the inlet or exhaust housing prohibited. Turbocharger compressor wheel must be constructed of cast or billet aluminum
Mike....my only problem with the rules is the seat location rule.
6.5 SEATS
In my my Mopar my seat was 6" behind the doorjamb and my old Chevy II it was 2" behind the doorjamb.
Why does it matter where the driver is in the car? Luckily in my Camaro the doorjamb is almost even with the wheeltub and I sit just in front of the jamb. The reason why I bring this up.....this rule hurts tall drivers like myself 6'6"and guys ike Tom Hammonds who is 6'8". I went rounds with the Democrat Road NMCA group years ago on this issue. I even sold one car due to the seat setback rule clause back then.
-Eric-
Jimmy Biggs said:
*Took a Brother to get the job done! :p Thanks Eric.....how about a Sledge update?
LOL :p
Will be doing an update between now and the weekend will possibly be running a 10.5 race this coming Friday and spraying it for the first time. :shock:
Got to get the new hood installed and the foggers wired up.
I agree. I had to go back and look at pictures of my cars build up. My shoulder is exactly in line with the door jamb. I had to pull the seat back that far just so I could get in and out through the door opening due to my height. There have to be other cars and drivers out there where that problem is just as bad or even worse. Seems like a strange rule. I can understand the need for controlling the setback. But, at the same time wouldn't controlling the percentage of weight on the front wheels really get what you're looking for?
6.5 SEATS
-Eric-
1 - 20 of 35 Posts
