Ok when I bought my rear end years ago I couldn't afford disc brakes AND the rear end so I had the rear end built with gm ends so i could re use my stock drums. Well I'm way past the point of needing better brakes so either I need to find a set of discs that will fit on my gm ends or swap them out for 9" ends.
Just wondering what is the going rate for having someone chop off my gm ends and weld on some 9" ones.
Any recommendations on an inexpensive rear disc setup would be great too. 72 Chevelle with 15" pro stars. Rear end is a Fabricated 9" from Moser with 35 spline axles Yukon nodular center with 3.70 gears, spool and billet pinion support.
