(August 2nd) - Saturday Night Street Car Shootout brought to you by Cecil County Dragway and Finishline Performance
The Outlaw 10.5 class is brought to you will special thanks from the following sponsors: Harris Motorsports, Shannon Mechanical Heating & A/C, Ferrick Construction, Red Alert Refinishing, Montana Brothers, Competitive Wiring, J&E Automotive
Qualifying Round 1
DRIVER R/T ET MPH
Dave O' Donnell - 0.173 6.90 @ 78
Steve Hicks - 0.212 4.98 @ 144
O' Donnell went 60 feet and had a large backfire through the exhaust and shut off. Hicks who smoked the tires earlier in a test pass comes out and lays down a nice soft run.
Steve Klueffel - 0.042 5.01 @ 144
Mo Hall - 0.031 4.73 @ 159
Klueffel is slowly working on getting his supercharged Mustang to go down and seemed to chatter the tires about 330 feet out but he drove through it. Hall mades a nice run but slightly off his usual 4.60's range
Joe Newsham - 0.060 4.62 @ 164
Charlie Dolbin - 0.103 7.31 @ 60
Number one and two in points always a battle between these two. Newsham made a nice pass to put him number one so far. Dolbin blew the tires off hard about 100 feet out and got crossed up and shut it down
Larry Wood - 0.093 6.43 @ 91
Mike Bradford - 0.051 8.87 @ 80
Wow both cars blew the tires off. Bradford's car usually goes right down, but he went up in smoke on the hit and Wood went out about 100 feet and overpowered the track and had to lift.
Paul Efontis - 0.44 4.95 @ 151
Daniel Fredler - 1.086 5.33 @ 138
Efontis coming out in his inline 4 cylinder Toyota makes a nice run. Fredler only 21 years old running the twin turbo Chevy II makes a soft clean run
Brian Weddle - 0.137 5.17 @ 126
Keith Sexton - 0.06 4.72 @ 160
Weddle's car was moving around he had to lift. Sexton made a nice run to put him in the field but was leaking trans fluid on the pass
Richard Sexton - 0.034 4.54 @ 166
Well Sexton is always a heavy hitter and he continues to show it everytime out as he throws his GTO into the number one spot and the first car in the 4.50s range today
Qualifying Round 2
DRIVER R/T ET MPH
Steve Hicks - 0.144 5.45 @ 142
Dave O' Donnell - 0.252 4.82 @ 157
O ' Donnell makes a nice run to improve on his last pass put him number five in qualifying so far. Hicks did not improve on his last run and remains number seven so far.
Mo Hall - 0.059 4.74 @ 155
Steve Klueffel - 0.427 5.04 @ 146
Well both cars are consistent today. Hall backs up his 4.73 pass and Klueffel backed up his 5.01 pass but neither driver improves and Klueffel remains on the bump so far.
Larry Wood - 0.052 5.63 @ 118
Wood blew the tires off again as his traction woes continue and he does not make it into the field.
Daniel Fredler - 1.637 5.39 @ 134
Joe Newsham - 0.111 4.63 @ 164
Newsham backs up his 4.60 run from earlier keeping him number two in qualifying and Fredler did not improve and does not make it into the field.
Mike Bradford - 0.048 4.94 @ 146
Paul Efontis - 0.42 5.31 @ 125
Bradford needed a good run to make it in the field and he did so. Efontis was smoking hard going down the track and did not improve but he remains in the field. Klueffel in his supercharged Mustang is no longer in the field
Keith Sexton - n/t @
Brian Weddle - 0.168 4.95 @ 143
Weddle comes out of no where to make it into the field so as the number 8 qualifer and knocks off Steve Hicks in his supercharged Nova.
Richard Sexton - 0.078 4.49 @ 165
Sexton was already sitting number one but he takes a hailmary pass and runs sub 4.50's. Just to note…the number two qualifier is Newsham with a 4.62…a notable gap!
Final Qualifying Order
1. Richard Sexton 06 GTO 4.49 @ 165
2. Joe Newsham 03 Cobra 4.62 @ 164
3. Keith Sexton 69 Camaro 4.72 @ 160
4. Mo Hall 94 Camaro 4.73 @ 159
5. Dave O' Donnell 70 Chevelle 4.82 @ 157
6. Mike Bradford 69 Mustang 4.94 @ 146
7. Paul Efontis 03 Toyota 4.953 @ 151
8. Brian Weddle 67 Camaro 4.956 @ 143
9. Steve Hicks 67 Nova 4.98 @ 144
10. Steve Klueffel 90 Mustang 5.01 @ 144
11. Daniel Fredler 67 Chevy II 5.33 @ 138
12. Larry Wood 89 Mustang 5.63 @ 118
13. Charlie Dolbin 90 Mustang 7.31 @ 60
Qualifying Round 1
DRIVER R/T ET MPH
Qualifying Round 2
DRIVER R/T ET MPH
