1 - 20 of 43 Posts
(August 2nd) - Saturday Night Street Car Shootout brought to you by Cecil County Dragway and Finishline Performance
The Drag Radial class is brought to you will special thanks from the following sponsors: DRA Commercial Handyman Service, PM Construction, Bigtime Automotive, Corupt Motorsports, Ellas Automotive
Qualifying Round 1
DRIVER R/T ET MPH
Eddie Himmighoefer - 0.241 5.67 @ 125
Ben Byrd - 2.020 5.39 @ 141
Himmighoefer seems to be giving the radial class a shot but down in the powerplant department. Byrd comes back out after missing a few races and makes a strong pass in his RX7
Chris Little - @
Scott Bitzer - 0.247 5.76 @ 135
Little broke and had to be pushed back. Bitzer was peddling the car all the way down the track
Chris Douglas - 0.518 6.4 @ 119
Richie Stine - 0.218 5.15 @ 143
Douglas is a first timer here in drag radial in his beautiful blue Mustang but is well off the mark. Stine mades a nice pass but is still off his usual 4.90 range.
Rich Bach - 5.41 @ 139
Chris Evans - 5.40 @ 133
Bach and Evans were side by side. Bach was a little off his normal mark and Evans continues to work out his traction issues and creep up on his setup.
Sal Patel - ,044 5.17 @ 144
Jesse Lambert - 0.082 5.93 @ 103
Patel makes a nice run in his V10 Viper put him number two for the session and Lambert lifted the wheels and moved towards the wall and had to lift.
Paul Major - 0.079 5.74 @ 147
Major's woes continue with his traction problems as he spins off the line yet again.
Alex Vrettos - 0.314 5.90 @ 127
Vrettos left soft and as he broughtin the boost he spun and had to peddle.
Qualifying Round 2
DRIVER R/T ET MPH
Ben Byrd - 4.15 6.81 @ 120
Sal Patel - 0.056 5.03 @ 145
How about Patel who goes straight to number one with a personal best in the Viper. Its early in qualifying and could get bumped but still a great pass for him. Byrd had problems off the line.
Chris Crown - 0.076 5.45 @ 145
Eddie Himmighoefer - 0.28 5.67 @ 125
Crown showed up late and had one shot at qualifying and he goes to number six so far. Himmighoefer does improve but not good enough to make it in the field.
Scott Bitzer - 0.342 5.2 @ 143
Chris Douglas - Deep n/t @
Bitzer makes a good pass to move to number three so far. Douglas went deep so he will not get an ET
Richie Stine - 0.15 6.92 @ 70
Chris Little - 0.088 5.37 @ 143
Stine was on a good pass but the car shut off around 330 feet. Little had a pretty good run and moves up a few spots.
Jesse Lambert - 0.115 5.13 @ 144
Tony Parsons - 0.63 7.83 @ 86
Lambert had a pretty pass carrying the front wheels and set the front end down and put him in the field. Parsons car has had ignition problems and had a nice nitrous backfire through the hood in the silver mustang.
Alex Vrettos - 0.481 4.98 @ 153
Well…Vrettos showed why he is one of the baddest cars out there and bumps Patel out of the number one spot and is the first car in the 4.90s today.
Chris Evans - 0.114 5.42 @ 134
Rich Bach - 0.128 5.38 @ 133
Evans carried the front end way out there and does not improve on his 5.41 pass and Bach makes another 5.30's pass.
Paul Major - 0.319 5.26 @ 148
Major finally pulled enough power out of the car to get it off the starting line and move him way up in the field.
Final Qualifying Order
1 Alex Vrettos 95 Mustang 4.98 @ 153
2 Sal Patel 99 Viper 5.03 @ 145
3 Jesse Lambert 95 Camaro 5.13 @ 144
4 Richie Stine 02 Camaro 5.15 @ 143
5 Scott Bitzer 81 Malibu 5.2 @ 144
6 Paul Major 01 Corvette 5.26 @ 148
7 Chris Little 90 Mustang 5.37 @ 143
8 Rich Bach 90 Mustang 5.38 @ 133
9 Ben Byrd 85 Rx-7 5.39 @ 141
10 Chris Evans 87 Mustang 5.41 @ 139
11 Chris Crown 92 Mustang 5.45 @ 145
12 Eddie Himmighoefer 92 Mustang 5.67 @ 125
13 Chris Douglas 84 Mustang 6.40 @ 119
14 Tony Parsons 87 Mustang 7.83 @ 76
Round 1 Eliminations
DRIVER R/T ET MPH
(W)Jesse Lambert - 0.105 5.10 @ 144
(L) Eddie Himmighoefer - 0.178 5.63 @ 126
Strong run by Lambert who continues to go faster and faster every pass. Himmighoefer was certainly at a disadvantage and Lambert took advantage
(L) Chris Douglas - 0.399 6.64 @ 115
(W) Sal Patel - 0.065 5.62 @ 135
Patel has been on all day but he gets crossed up and does a nice job on recovering and driving it on out for the win.
(L) Chris Crown - n/t @
(W) Richie Stine - 0.882 5.09 @ 143
Well Crown who showed up late and made it in the field on the second qualifier fouls his day away as he rolls through the lights giving the win to Stine
(L) Chris Little - 0.030 5.07 @ 149
(W) Rich Bach - 0.110 5.31 @ 134
Bach had a better 60 foot than Little but the single turbo Mustang brought in the boost and just drove past the nitrous small block for the win.
(W) Paul Major - 0.005 5.08 @ 148
(L) Ben Byrd - 0.394 5.70 @ 141
No contest as the pair of turbo cars squared off. Major was deadly on the tree and the car is coming around nicely.
Scott Bitzer - 0.164 5.10 @ 144
Bitzer gets the solo run as he gets the single due to breakage and makes a nice run as he is working out the new motor in his cool lookin Malibu
(W) Alex Vrettos - 0.109 5.32 @ 133
(L) Tony Parsons - 0.189 7.13 @ 106
Parson's problems continued and Vrettos carried the front end and set it down but had to peddle but had no problem ending Parsons day.
Discussion Starter · #11 ·
Round 2 Eliminations
DRIVER R/T ET MPH
(W) Scott Bitzer - 0.122 5.04 @ 145
(L) Richie Stine - 0.085 5.08 @ 144
Big upset as Stine goes out. Good side by side race as Stine left first but Bitzer drove around him!
(L) Chris Little - 0.081 5.09 @ 149
(W) Sal Patel - 0.042 5.08 @ 142
How about Patel! Close drag race. Patel left first and holds off Little as it appeared Little was going to drive around Patel but he holds him off and goes on to the next round.
(W) Paul Major - 0.094 4.97 @ 153
(L) Jesse Lambert - 0.042 5.7 @ 125
Well I thought this would be a closer race but it was no contest and Major just muscled his way down the track to his first 4.90's pass of the year as the team has finally figured out their setup on the wild Corvette
Alex Vrettos - n/t @
Vrettos has the bye so he just took the tree and backed out.
SOFA KING WHAT?
We are still here and filming each round of qual and all the radial racing and will have it posted tomorrow.
Discussion Starter · #15 ·
Semi - Finals
DRIVER R/T ET MPH
(W) Paul Major - 0.04 5.15 @ 152
(L) Sal Patel - -0.009 5.14 @ 141
Patel was first to the stripe but fouls it away by 9 thousandths…would have been a good drag race but Major is going to his first final this year but still worth giving Patel credit for an excellent outing here tonight.
(L) Scott Bitzer - 0.463 9.42 @ 54
(W) Alex Vrettos - 0.132 5.38 @ 129
Vrettos had troubles earlier after hurting something but it appears he got it fixed. Bitzer had problems after he launched and Vrettos let off and coasted for the win. Major will have lane choice in the finals.
Discussion Starter · #16 ·
Finals
DRIVER R/T ET MPH
Paul Major - 0.086 5.50 @ 122
Alex Vrettos - 0.114 5.31 @ 142
Well it wasn't pretty but Vrettos and Team Corupt were able to fix the car and take the win against Paul Major. Both cars started to carry the wheels and Major had to peddle the car and Vrettos was able to get a reigns on the car first and drove by Major for the win. Congrats to Corupt Motorsports for their second win this year.
Im just getting home after the ride back from cecil and a late night dinner. I was impressed on how the show was run and glad to see all the racing get done. And Three J&E powered cars in the final races. Joe Newsham won in outlaw,alex in drag radial and Mark Boman runnered up in the 8.50 class. Congrats to everyone!!!!
Greg
X275 O.G.
great coverage!!!!! you guys rock.. i think we found or issue with lack of horsepower. it's safe to say i'll be down and out for alittle bit :(
There is no hair dryer under your hood.FordRules:
SOFA KING WHAT?
Get some good pics of my buddy Brian and his ATI Procharger powered Pontiac. Tell him I said Hi.
That is one badd azz car! His buddy with the N/A Firebird is also hauling ass, RHODES does a great job on those cars.
1 - 20 of 43 Posts
