1 - 7 of 7 Posts
(Aug 1st) - Cecil County - Finishline Performance Outlaw Street Car Shootout
Drag Radial
Qualifying Round 1
Driver R/T E/T @ MPH
Chris Evans n/t @
Jesse Lambert 6.18 @ 127
Lambert smokes the tires at the hit. Evans had a nice 5.08 in testing but the car is doing what it did last month..bog on the hit..so its back to the drawing board for that team
Brian Krzewinski 0.252 6.01 @ 138
Don Barnett n/t @
Barnett is shut off for leaking. Krzewinski brought in the power in the single turbo Firebird and smoked the tires and had to peddle
Brett Hull 0.31 5.02 @ 151
Scott Bitzer 0.117 5.53 @ 140
Hull had a nice test pass and went 7.70s to the quarter mile and also blew out the sunroof so he taped it up so he can continue to run here today as he stated Cecil County is just dying to get a piece of his car as he always seems to have problems but he posts up a very stout number here in the single turbo machine as Bitzer started to lift the wheels and he spun and had to peddle
Adam Gupsailor 0.143 6.49 @ 90
Glen Buckler 0.19 5.25 @ 140
Guppy spun and had to peddle. Buckler is wheelin' a nitrous Camaro and puts up a decent number in this first round of qualifying
Steve Thompson 0.093 5.55 @ 134
Small block nitrous power here as Thompson left very soft and brought in the nitrous
Bill Weber 0.114 5.62 @ 118
Paul Major 0.237 6.54 @ 74
Weber has been MIA in radial for a very long time in his yellow Camaro looks like he is sorting things out. Major blew something up and there was a HUGE cloud of smoke as his woes continue! It appears there was a small fire under the car as well…this is going to take a while to clean up....
Alex Vrettos 0.18 5.20 @ 142
Dwayne Gutridge -0.013 6.49 @ 93
Well we made the call to spray the track again after the clean up and neither of these two powerful machines liked it as they both had traction problems
Bill Dutka 2.33 6.50 @ 132
Dutka has the Malibu out for its debut FINALLY after being whipped up on in his Monte Carlo first round every month
Discussion Starter #2
Drag Radial
Qualifying Round 2
Jesse Lambert 5.40 @ 134
Adam Gupsailor 5.64 @ 140
Lambert still shaking out the car as for Gupsailor he gets the car to stick and puts up a nice number for the big steel bodied Mopar
Glenne Buckler 0.155 5.20 @ 143
Brian Krzewinski 0.049 5.40 @ 116
Buckler runs another low 5.20 pass and Krzewinski steps it up but the car was breaking up and had to lift early
Scott Bitzer 0.129 5.58 @ 140
Don Barnett 0.131 5.74 @ 130
Bitzer had some problems and Barnett fixed his oil leak but the car wasn't chrisp but he makes a qualifying effort to make it in to the field
Bill Dutka 2.66 5.56 @ 138
Bill Weber n/t @
Weber rolled through the lights and Dutka stepped it up as he is figuring out his twin turbo Malibu
Dwayne Gutridge 4.81 @ 161
Brett Hull 5.02 @ 133
Big Daddy goes to number one as he is the first to go in the 80s today as the track is cooling off. However Hull should not be overlooked as he is still number two qualifier with the single turbo powerplant
Alex Vrettos 0.191 4.77 @ 162
Chris Evans 0.465 5.16 @ 146
Evans has to be happy that the car didn't bog and he moves way up in the ladder. Vrettos just moved right on past big daddy and went to #1 . So we saw our first 80's and 70s pass this weekend here in qualifying. I expect big things 1st round of eliminations as it continues to cool down and the humidity drop
Steve Thompson 0.097 5.41 @ 134
The little small block power that could. Thompson is bringing a knife to a gun fight but still qualifies here tonight
Drag Radial
Round 1 Eliminations
Steve Thompson 0.100 5.20 @ 137
Brian Krzewinski 0.123 7.91 @ 65
Thompson FOUND some power in the small block nitrous car as surprises quite a few people I'm sure and Krzewinski popped around 60 feet and had to lift
Chris Evans 0.058 n/t @
Bill Weber n/t @
Well this for lack of better words…SUCKS for Weber as Evans left and spun and broke something and Weber's car backfired on the starting line and never left soooo I believe Evans takes the victory even though he never crossed the finishline
Brett Hull 0.275 5.00 @ 152
Jesse Lambert 0.068 7.32 @ 88
Hull still looking for the 4 second zone with a very clean run. Lambert hit the throttle and went no where as Randy Lambert and crew keep scratching their heads
Adam Gupsailor 0.06 5.42 @ 134
Scott Bitzer 0.113 5.65 @ 141
A little upset at Bitzer spun and tried to run Guppy down but the big green Mopar held him off for the win
Dwayne Gutridge 0.157 4.8 @ 162
Big Daddy gets the single due to breakage makes a nice run but I'm sure he has a little left in the oven to pull out here tonight
Alex Vrettos 0.234 4.72 @ 167
Vrettos gets the single due to breakage as Paul Major was unable to fix the trans and Vrettos has to be happy as he is creeping up on his magic tune up
Glen Buckler 0.173 5.40 @ 143
Buckler ALSO getting a single and he was breaking up all the way down track
Drag Radial
Round 2 Eliminations
Glenne Buckler 5.01 @ 148
Chris Evans n/t @
Evans just staged to get the point as he was broke. Buckler steps it up big time as he sorted out the nitrous issues and puts up a very nice number
Brett Hull 0.233 5.46 @ 121
Adam Gupsailor 0.078 5.36 @ 136
Hull was dead late and had some issues and had to get out of it and Gupsailor pulls out the upset
Dwayne Gutridge 0.048 5.70 @ 128
Steve Thomas 0.239 9.5 @ 68
Gutridge was pullin the wheels up and had to peddle and then moved towards the wall and had to pull it back in and as for Thomas he was loading it up in the small block nitrous car but had issues on the line and Gutridge gets away with one here and moves on
Alex Vrettos 0.259 5.46 @ 100
Vrettos left pretty decent but moved towards the wall as well and had to dump
Drag Radial
Round 3 Eliminations
Glenne Buckler 0.068 4.99 @ 150
Alex Vrettos -0.011 4.86 @ 140
Vrettos fouls it away as he had him at the finishline but that’s why they call it a drag race. Not taking anything away from Buckler who stepped it up again and dips into the 4's with the nitrous Camaro
Adam Gupsailor 0.026 5.39 @ 137
Dwayne Gutridge 0.014 4.94 @ 148
Guppy put Gutridge in the right lane but it didn't matter. Guppy good on the tree…Gutridge was better and was pretty much a no contest. Big Daddy will have lane choice over Buckler in the final
Congrats Big Daddy on the win
Congrats Alex on some fast passes
6's are just around the corner for both of you guys
1 - 7 of 7 Posts
