1 - 20 of 60 Posts
We bought a 572 inch 720 hp. at auction the owner died his widow was selling his race car and parts, auctioneer said the engine was rebuilt, now problem when we got it home we found out it was stuck , cant turn it with a bar. sprayed the cyl, with wd 40 it sit for two days still no turning, called the auctioneer he got red like smart ass, it was supposed to set for two years after it was supposed to be rebuilt, has anyone ever had this problem?
looks like we are stuck with a bad engine,
thanks odie,:confused:
how much u pay?
Try automatic transmission oil, it could be the bottom end.we normally flipped them and filled it from the bottom....
El Diablo
You didn't even try to turn it over with a bar or anything, just trusted what the auctioneer said?
Shouldn't have bought it for any more than what a locked up engine should bring.
Medium Pimpin'
Sometimes you score at the auction sometimes you don't. I snagged a D-3c Procharger for dirt cheap. Miss-directed freight auction. Was on the way back from ATI to the customer.
Put Custom Title HERE!...
I'd assume that ANY engine I bought from an auction, wasn't ready to just drop into a car!...
I'd pull the thing down far enough to at least KNOW what the engine consisted of!... :smt102
when your at a auction, and they dont/cant start up some thing always assume the worst and bid that way. my dad got REAL luck when he bought a massey-fergason 180 for $1000. all it needed was a water pump. got it up and running and had a valve issue, but he used it for a year then rebuilt it.
Customer User Titty
X2.. You gotta assume the worst with auction items otherwise you're taking a huge risk.
Auctioneer's words are just like the info you get off the internet, it's always accurate and true. Good luck with your engine. :p
sixthousand,sixthousand,sixthousand,sixthousand,sixthousand can I have seventhousand? sixthousand,sixthousand,sixthousand,sixthousand .................. ...............SOLD tothesucker,imeangentalmanintheracingshirt.
HAMMERDOWN
You are stuck with it
El-conquistador, sir
Dont even dick around by prying it. Pull the heads and if your answer has not been revealed, pull the pan. Its obvious somethings jammed, no since breaking it lose and firing up a hand grenade. You need to know whats going on before anything else.
X2
1 - 20 of 60 Posts
