1 - 3 of 3 Posts
workin it
Hey Ray, got the alternator today and I was hoping you could post up what the wiring schematic for it was...I have an external regulator with a fuse in it, will this work? If not, how can I wire this alternator up for maximum ease and maintenance? Thanks, Scott
I should have drawn this out for you, as it is pretty complicated. You need to put a large guage wire (use chart at top of forum, at about 150amps, the alternator did 200amp but you wont use it all) from the stud on the back of the alternator to the positive terminal on your battery. After you get that step done, you might want to go have a beer, as you are finished. LOL.
workin it
You're killin me Rayyyy, thanks:rolleyes:
1 - 3 of 3 Posts
