1 - 3 of 3 Posts
HI more questions in regards to my th400 problem, are all dex 3 fluids created the same even if they do have for gm stamped on container im brought 20 liter container called TOTAL dex 3 made in singapore, has anyone every had extra slip in converter due to crap brand off dex 3 ,can overfull th400 cause converter slip due to airation in oil ,how much extra slip do you guys see in stall with fluid temps rising making trans fluid thinner
thanks
victtor
new zealand
Different oil companies use different base stock to make the ATF.. Some companies usea a higher quality than others.. So not all ATFs are the same quality even though they are marked Dexron 3.....
1 - 3 of 3 Posts
