1 - 6 of 6 Posts
i am hearing and seeing an arc inside my jesel beltdrive cap when cranking the engine around with ignition on.
i have a new hvc-2 coil new 7al box new cap and it still does it,i only have ONE deep cycle battery in the car, any ideas?thanks
about a billion years ago I used to race VeeWee's & the "trick" thing to have on them was clear (or smoked) distributor caps. they were cool becuase every time the rotor would line up with a plug, & the coil would fire it would arc & create a spark that flashed as the car went down the road (we did not run "hoods"). SO........ does the car run? are you sure its not supposed to do it? How are you seeing it under the cap? have you drilled a hole in it to phase it?
Bob
1 - 6 of 6 Posts
