1 - 2 of 2 Posts
Not the greatest with wiring, but I purchased an arc8000 and am trying to wire it all up. Car already has 2 relays, one for the transbrake and one for the nitrous solonoids. Cuts power to the nitrous relay when I am on the brake. How should I go about wiring in the arc panel that has the relays mounted to the circuit board.
just going to use one of the outputs on your ARC panel for your nitrous Arming switch that is normally in the pin 86 spot of your current nos relay
1 - 2 of 2 Posts
