1 - 6 of 6 Posts
I have a built aod built by lentech and it acted fine on the dyno. But after running up the highway a bit and throwing my car a beating the trans feels like the lower gears are binding or reverse is kicking in when it shouldn't. If I put it in third it is fine. 1rst and 2nd gear act like reverse is fighting them and if I put it in reverse it will stall the car. Only does this after I go up the road and beat on it. After it cools its fine again.
sounds like the direct clutchs have to little clearance or the steels have warped. I really dislike those alto Red frictions in the direct. That zpack thing they also sell for the directs is garbage to.
Like was said, sounds like bindage from warped clutch...or if this is a REVERSE THIRD vb, i just repaired a lentech trans that had this VB. Len (or his vb builder) forgot to plug a hole in the circuit and smoked the rev clutches to a pulp. Mistake yes, but yours could be the same.
1 - 6 of 6 Posts
