Currently have a overly tight converter spec’d for a much larger motor.
I threw a 4.8 in the car to finish out the season while I finish building up a larger motor. With -20* of timing I can manage 4lbs of boost and 3000rpm on the trans brake. When I release the brake boost falls and the car bogs to 4k before the turbo lights off.
Recently threw a n20 dry kit on I had laying around. Using Mega Squirt to control this and cut the nitrous off at 4k. Using a .035 jet (maybe 50ish hp?) I’ve still yet to fill the bottle and plan on disabling the anti-lag/timing retard on the 2step.
Question is, if I’m still having issues. Should I just keep upping the jet size? Or should I incorporate some sort of anti-lag in addition to the nitrous? I can add or subtract as much as 40* on the brake.
