1 - 11 of 11 Posts
just wondering on this brand thay make a pretty big 10.50w but i dont see them at the track are thay good or junk?:smt102
I got a pair on a truck I bought a couple years ago, they were probably 5 years old then. They still work just fine. 13x31x15W
thanks for the input ive got mt's now & i run tubes but the phoenix is about 1 in wider & 1/2 in taller i could use both but not if thay dont hook lol.
Dinosaur Mechanic
I have a set.and they work good, but yes they leak without tubes..........going to try and coat the sidewalls with dish soap inside and see if it helps. otherwise They are both flat in 2 days.............
On the roller...
كافر
friend used some for years, probably still does, deadly consistent with them. and won a lot of times..
I run PH 338's on my car.
I tried a set of the 10.5 W tires on it earlier in the year and only got 56 passes and they were shot. I suspect I got an old set from before they moved the operation.
These 338s are much better. I have RU and won with them on some pretty shitty tracks since I put them on last month.
1 - 11 of 11 Posts
